Pouzity material - nerezove struhadlo na kren, prace cca 10 minut
LR 88 SIII - Koprivak
Moderátor: Rover
Re: LR 88 SIII - Koprivak
Tak se mi vcera podarilo situaci vyresit temer bez bastleni.
LR 88 SIII "Koprivak"
Velorex 16/350
Tatra 603/II, model 1967
Ruzne zadokolky od Volva, serie 2,7,9
Velorex 16/350
Kolikpak stojí takové struhadlo? Taky mně to čeká u LR110...
Prosim pekne 45 kc. Kdyby melo vetsi hodnotu, nabidl bych Ti zbytek z toho meho, ale takhle se to skoro ani nevyplati posilatRover píše:Kolikpak stojí takové struhadlo? Taky mně to čeká u LR110...
Velorex 16/350
Velorex 16/350
No to jsi šikula
Třeba bys to mohl ve velkém dodávat do Craddocka!
Vidíš,to mně nenapadlo...vždy jsem se to snažil řešit originálními díly když byly dostupné,ale tomuhle řešení myslím nejde nic vytknout.
k.
k.
Tak jsem se tesil, ze mi kazdou chvili dorazi papir z Anglie, ze ktereho se dozvim neco vic o Koprivakovi a misto toho tohle:
On 8/16/2016 15:39, Richard Bacchus wrote:
Dear Mr Stanek
Thank you for your order. Your Land Rover is a CKD (complete knock down) exported from the UK in component form and assembled overseas. As a result we do not have the build record for the vehicle and are therefore unable to produce a Heritage Certificate. I will therefore arrange for you to be refunded.
Regards
Richard Bacchus
Certificate Officer
British Motor Industry Heritage Trust
Heritage Motor Centre
On 16 August 2016 at 17:38, Lukas Stanek <olivin4@yahoo.com> wrote:
Dear Mr Bacchus,
Thank you for your reply. Since I have no records about the vehicle history I would appreciate any information about my Land Rover. Are you able to find at least when the components were despatched from Solihull and what was their destination? I mean where the car was assembled?
Thank you in advance.
Best regards
Lukas Stanek
On 8/17/2016 08:51, Richard Bacchus wrote:
Dear Mr Stanek,
Unfortunately there is no surviving record, the chassis number prefix 903 defines a Series III 88 inch petrol basic CKD, so we can't even say to where the component parts were despatched to. The two biggest right hand drive CKD destinations were South Africa and Australia, so it was most likely built in one of those countries.
Regards
Richard Bacchus
Certificate Officer
Takze jsem tam, kde jsem byl pred tim - nevim nic
Dear Mr Stanek
Regards
Richard Bacchus
Certificate Officer
Dear Mr Bacchus,
Best regards
Lukas Stanek
Dear Mr Stanek,
Regards
Richard Bacchus
Certificate Officer
Velorex 16/350
Velorex 16/350
Dneska jsem se konecne troosku pohnul smerem vpred. Vymena vodni pumpy, svicek, solenoidu, opetovna montaz predniho kardanu a hura na testovaci jizdu
Tesne po opusteni dvora jsem vsak zaznamenal pomerne vyrazne rany spod predni casti auta. Po navratu se ukazalo, ze zminene zpusoboval predni kardan, jez mel diky zvednutemu podvozku vetsi uhel nez na jaky byl staven, takze mlatily krize o priruby. Jakmile jsem vymenil predni houpacky listovych per pochazejici z "One Ton" za originaly (mimochodem zvlast vyzivna prace na aute co stalo leta v koprivach), tak mlaceni zmizelo a Koprivak jel jako vitr.
Byl jsem uprimne prekvapen, jakou to auto ma trakci - vzal jsem ho v Hodkovicich do krpalu na letiste, kudy jsme jako kluci jezdili motokros. Koprivak k memu prekvapeni vyletl onu "dabelskou" trat celkem bez problemu a nahore si proklestil cestu mlazim az na letistni plochu! Opravdu parada
Abych nezapomnel, jeste jednou diky tem, co mi dopomohli k original diskum.
Velorex 16/350
Velorex 16/350
Klucina musí být nadsenej ... konečně pořádne auto a ještě může sedet na kapotě
Teda!
Uvedení do provozuschopného stavu bleskovou rychlostí... gratulace
BTW: Jaké gumy jsi nakonec pořídil...? Také mne to čeká... Díky...
Jirka
Jirka
to vypadá na Michelin XZL nebo jsou to nějaké protektory?
Ahoj,Poly píše:Teda!Uvedení do provozuschopného stavu bleskovou rychlostí... gratulace
Jirka
gratulace je zatim predcasna, ale i tak diky. Koprivak sice jezdi jako drak, ale zatim bohuzel ne zcela legalne. Jak jsem tu citoval, britum se nepodarilo dohledat zadne zaznamy a ja se stale nechci smirit s tim, ze budu mit v papirech rok vyroby 1981 (datum prvni registrace v Britanii) kdyz vim, ze auto je stoprocentne starsi.
Gumy jsem nakonec poridil Michelil OR XZL 7.5x16, jak spravne odhadl Neklan. Puvodne jsem chtel Avon Rangemaster, jenze je celkem problem je sehnat. Par eshopu se sice tvari, ze je maji za slusnou cenu, lec po telefonatu na jejich dostupnost z nich vyleze, ze je vlastne nemaji a ani nejsou schopni je za nabizenou cenu dodat. Co jsem navic cetl na ruznych zahranicnich forech, nejsou na ne uplne nejlepsi reference... Zkratka a dobre, nejlepe mi pomerem cena/vykon vysly zminovane Micheliny - dle recenzi dobra trakce, vyborna zivotnost a stale jeste rozumna cena.
Velorex 16/350
Velorex 16/350
Michelin XZL vypadají jako velmi dobrá volba... I na pohled nijak neuráží a to se o mnoha modernějších dezénech říct nedá...
Díky za tip... !
Jirka
Díky za tip... !
Jirka
Tak jsem vcera byl po zime vytahnout Koprivaka od znameho ze stodoly a cekalo me pomerne nemile prekvapeni. Po pripojeni baterky a napumpovani benzinu jsem zkusil otocit klickem v zapalovani a ono nic
Respektive posledni poloha, ktera spina starter jakoby neexistovala - skoro mi to pripada, jako by tam pres zimu nekdo vlezl a zkousel se necim rypat ve spinacce. Od toho plyne muj dotaz, jelikoz si tenhle detail nejsem schopen vybavit - Kdyz zasunu klicek do spinacky a otocim do prvni polohy, nedeje se nic, telo spinacky pouze zajede kousek dovnitr. Ve druhe poloze se mi rozsviti kontrolky a dale uz klickem nejde vubec hnout
Je mozne, aby se pres zimu sama od sebe (v suche stodole) rozpadla spinaci skrinka? Zazil uz nekdo neco podobneho?
Auto jsem ve vysledku nastartoval na prvni otoceni klikou, ale absence starteru je preci jen ponekud tiziva.....
Velorex 16/350
Velorex 16/350
Spínačku ven, rozebrat a uvidíš. Zámky na LR nejsou nic moc a umí se různě rozhasit. A jestli se někdo snažil šroubovákem, tak to může být všelijaké.
O zamcich jsem to uz bohuzel zjistil. Kuprikladu leve dvere jdou sice zamknout, ale po par zalomcovanich klikou se zase klidne otevrou.MadTom píše: 29 bře 2017 17:51 Spínačku ven, rozebrat a uvidíš. Zámky na LR nejsou nic moc a umí se různě rozhasit. A jestli se někdo snažil šroubovákem, tak to může být všelijaké.
Jeste jeden dotaz - ma SIII zamek volantu, nebo nema? Nejak si nejsem schopen vzpomenout....
Velorex 16/350
Velorex 16/350
Ja WD40 nerad, ale prostrikal jsem to Konkorem - efekt zadny. Zkusim ji rozebrat a uvidime. Cim si nejsem absolutne jist je zamek volantu, neb si nejsem schopen vybavit, jestli se v loni rizeni zamykalo ci nikoliv...
Velorex 16/350
Velorex 16/350
Tak jsem se o vikendu zkousel dostat ke spinaci skrince. Cestou jsem narazil na jeden pomerne zajimavy prvek, jehoz funkci tak nejak nejsem schopen pochopit.
Pomuze mi prosim nekdo identifikovat, k cemu slouzi ten nalitek na tele spinaci skrinky???
Velorex 16/350
Velorex 16/350
Máš tam spínačku z Diesel,to je chcípák motoru.U benzínové verze tam má být sytič.Ten máš tedy asi někde jinde.
Sytic mam pravda jinde, nicmene, auto je benzinove jak papirove tak v realu. Krom toho je spinacka pridelana k volantove tyci original trhacimi srouby. Ze by si nekdo dal tu praci a vymenil celou volantovou tyc i se spinackou se mi nejak nepozdava....kryten píše: 03 dub 2017 07:49 Máš tam spínačku z Diesel,to je chcípák motoru.U benzínové verze tam má být sytič.Ten máš tedy asi někde jinde.
Velorex 16/350
Velorex 16/350
