A problem with my car.
hellozaizai
- tel.: 1500508600
- auto: Landrover TDV6
Landrover D90. It got caught up in a flood and was soaked up to the hood. It was taken for a scan and the scanner couldn't connect to the ecu. So what next do i do as i couldn't get a scan result. Does the tool named UPA USB used for me ? If you know please tell me . Thank you.
where there is a will there is a way
- Mirko
- auto: RRC´s
Re: A problem with my car.
a D90 with a TDV6, as your profile says? I´m not aware of such a car being ever produced. So please tell us: which year, which engine. But even than: As teslo told you in your first tread, nobody will probably have any experience with those tools here. It´s easier to buy tools from the EU than US for most of us on the Czech forum.
if your car was flooded up to the bonnet, than i would start with checking all electric connections(disconnect and clean).Than take a close look at ECU.
hellozaizai
- tel.: 1500508600
Thank you for your help , but it can't solve my problem , help me please
Uff, Is your defender truly TDV6? Therefore it was modified by someone becuase a TDV6 was not an option for Defender. If yes, than i would suggest to contact that company (or person) for help. Maybe that is also reason why diagnostic is not working, because there is different ECU etc...
hellozaizai
- tel.: 1500508600
thanks very much for your help, and i have solve my problem
- paramount2
- tel.: 775958013
- auto: LR D1 300, D2 TD5
mno...já bych řek, že mu ani tak nejde vo pomoc...spíš se snaží propagovat ty diagnostický mašiny, na který má v každým topicu vodkaz....
hellozaizai
- tel.: 1500508600
thank you for all of your help and i had solved the problem in a garage
